camarors8992
- Liverpool, New York
Anyone know a good location to mount the amps ?
txredxj said:WOW! imagine all the poor bear cubs that it took to cover that box
Under the rear seat, on the sub box, on the rear floor, on the back of the rear seat, on the headliner(best one I've seen yet!), etc. Is is that hard to find a spot?camarors8992 said:Anyone know a good location to mount the amps ?
xjblue said:My new box is designed, cut, assembled, and test fitted. Just needs weather sealed, speakers wired, caulking and reassembly, hardware for cargo area access attached, some gray carpet, and solid tie downs. Birch Ply this time, used two sheets so I'd have plenty to spare and for another idea I have in mind. I found some at Home Depot (second store I went to) for suprisingly not much more than MDF.
Birch Ply vs MDF in my experience
pluses
Birch holds screws like wood (MDF is like old pudding)
Birch is more forgiving of drilling angle accidents:sad1: (MDF tears up easy)
Birch smells like wood (MDF smells like something)
Birch is stronger while quite lighter (MDF heavy)
Birch looks like wood (MDF looks like leftover sawdust, I'll cover it anyway)
minuses
Birch outer surface layer peels a little bit during drilling, cutting, handling
(i'll cover it anyway)
Birch is more expensive
Whats a good speaker wire to use?
For sub inclosures, the biggest advantages would be uniform consistency of material, resistance to vibration, and more of an air tight base.5-90 said:Principal advantage? I believe that MDF is easier to "steam and shape" into true curves, and it's cheaper because it starts life as "mill scrap."
I'm not an expert, but lots of people in the audio forums go for knukonceptz.com I didn't run any tests or anything, but visually, their speaker cable appears to be of a higher quality than monster cable, and it's cheaper to boot. Their battery terminals are a bit spare, but functional and cheap, and I've read one or two accounts of people who felt underwhelmed by the distro blocks. Fast shipping and customer service though.xjblue said:Whats a good speaker wire to use?
do you have any pics994x4xj said:im having a 8'' sub installed inside of my center consule on my 99 xj
BBeach said:Do you have any plans on how you made that? That stealthbox looks pretty sweet. Whatd you make it out of and how did you run the wires? Looks good.
