BRIANHO13
<- Yum Chocolate
- Spring, TX
Looks good, but you might need a little longer shock now, looks like you still have some more down travel to be had :cheers:
x2BRIANHO13 said:Looks good, but you might need a little longer shock now, looks like you still have some more down travel to be had :cheers:
razdrvr said:
WheelinJR said:It also looks as if your shackle is contacting the hanger on the compression side.
it's a condition where the application of power to the rear wheels causes the rear of the vehicle to lift and the tires to push down, increasing traction .. think equal and opposite reaction .. in short; ass lifts, tires planttechno1154 said:Ok. Educate me :dunce: What is 'Anti-Squat' and why is it undesirable?
anthony said:it's a condition where the application of power to the rear wheels causes the rear of the vehicle to lift and the tires to push down, increasing traction .. think equal and opposite reaction .. in short; ass lifts, tires plant
the squat part is undiserable because it unloads the tires and allows them to spin easier
TNT said:With too much of it you can walk the axle under the rear as the body raises and can also cause wheel hop when the tires spin and grip again. It was most noticable when loading the suspension up against an obstical. It would also hop in 2wd when screwing around doing burnouts.
WheelinJR said:A nicely built shackled ladder bar ought to remedy most potential issues, no?
TNT said:It will help, but the springs are meant to be mounted at the proper angle. The biggest issue is the spring angle, the rear mount is moved down to far.
Starting at 4.5" and above you should be looking at DB's or LA's.Dont forget about trackbar and steering issues also!Silent said:I have a question. I have a RE 4.5 Super Flex waiting to go in. If I use my ACOS I have and get this shackle relocation system, will I need new and longer control arms up front? I am just worried about changing the geometry under the vehicle by going higher.
Thanks,
Silent
