Anyone know how makes this trackbar mount?
Dunno
looks similar to https://store.jksmfg.com/merchant2/...0_925&Store_Code=JKS01&Category_Code=FABParts
just my opinion, but if you goto anything other then a poly/rubber bushing, aka a hard joint of somekind... there will be vibes/noise transferred.
I am using 1 1/4" heims on both ends, considering the use of the vehicle the small amount of vibes shouldn't matter that much.
so be it ballistic joint, evolution joint, heims, etc there will be vibes. so I went for what I figure will be the longest lasting, strongest joint for the money.
How bad exactly are the vibes?
It seems like a lot of things get hyped up on the interwebs, for example, a lot of people hate an aussie in the front axle in the snow. Supposedly youll drive your rig right off a cliff, i ran that setup for 2 winters, and i loved it.
Maybe ill just have to run it and see for myself.
If you wanted to come to NH for that swap we could do it in my garage.Ok, so i didnt really like wheeling with 3.73s 33s and a 5 speed, hopefully it will be better with the 4.88s 35s and a 5 speed.
Now, if i still dont like it, id be willing to swap in an aw4. Id also be willing to trade my ax15 (78k) and all needed accesories, hopefully to someone more knowledgeable when it comes to swapping transmissions. So yeah, just getting the word out there.
How did you like the front spool?
Stock steering? If so you will get bump steer with your track bar set up as it is. If you go crossover you would have them closer in length.
Warns just work and and it is easy to get parts for them.
