Talyn
- Radford, Communistwealth of Virginia
Well, the Isky problem was my fault. Even though the dots ont he timing set lined up, it was still a tooth off. Fixed and degreed.
Its running well. Started up on the first try like nothing ever happened. Broke the cam in for 30 minutes(felt like 3 hours), drained the oil after it cooled off and filled it with fresh oil and new filter. Only thing that concerns me a bit is that with 10w-30 oil hot idle oil pressure is 15 psi. Its not under spec, but I had around 30 PSI previous. I'm going to keep an eye on it, perhaps the pump isn't as tight as the previous one. Idle is around 600, and a bit rough (just like the Comp Cam 68-231-4). The valve train is much quieter. I can't really tell a difference between the Comp Cam and this one, but it has also been a while since I have drove it. The hesitation and stalling issue is gone, guess it was from the damaged cam. I'm going to re index the cam sensor because I don't like the direction its pointing, more to the passenger side then straight back.
Now for the bad... that damn knock from the bell housing is still there!!! Two transmissions, 3 torque converters and the engine gone over with a fine tooth comb. The torque converter to flex plate bolts are torqued to spec at 28 ft/lbs. I don't know.
