Zips 2.0 My 98 build
:cheers:
Dont just weld in your shock mounts. I plated but it wasnt enough.
I started stripping the jeep
More prep work
Stiffener getting ready to be installed
3 link parts.
This should be getting better, I really want to get out a lot more this year, Ive laid back on being a **** wits. I realize I was awful before, and yeah. :dunce:
I cleaned it all up all the way down to bare metal
The first picture shows where I welded the 1/4 plate that I drilled and tapped for the ford shock towers
Rear lockers out
I blew it up. Let's see how good powertrax is with warranting it.
Welded in the shock tower and primed that whole stiffener
Primed and painted my front drivers side stiffener
Cleaned up the passenger side stiffener
Came home to a box of happiness RUFFSTUFF 3 link parts and corned beef and cabbage!
Shitbox is still a shit box. I grenades the rear end up at Manson. I bought a Ford 9 but I need to narrow it. So I hucked a new carrier into the 8.25. Lokka ready to go in.
Also did mopar stage 3 can and tuned ecu. New accel plugs distributed cap and rotor plus some ngk coppers.
I got air and tore the unibody where I welded on my shock towers. It took cracked the etiffener and unionist under it on both sides. Lesson learned. Time for actual rear bump stops and some form or another of a crossbar that ties into the floor and rear suspension mounts
Decided to just do a quick patch because after all it is an xj and I want to wheel again. I plan on parting this thing out at the end of the year and going to another xj that hasn't been beaten as bad as this one.
Isuzu twelve bolt has been installed and is being ran welded.
welded up some perches
started tearing my upper control arms out so I picked these up.
some random in repair pics
