Zips 2.0 My 98 build
Ok so I have a question for you all.
With the abs if I just pull the lines and the fuze will I have any issues other than the light?
cut and folded
I just got a job finally
Working in an auto shop doing bitch work but it beats my current situation
Some times you just have to let shit fly
Dat lean.
Story time,
I decided to take my girl My bro and his girl wheeling
It went fine until I got to the rock ledge that had been covered in mud, so I tried the usual just bump it.
Instead of hopping up it slid me off to the side so I readjusted and tried it again
doing this in the process
Yes that is a bent tie rod and I bent the actual rod end.
I know Im a retard for wheeling with the stock one.
So we fixed that up and here is a pic of us pulling it out.
I had all 4 33s smoking like mofos I am unlocked.
The rock rocks now have a decent rubber coating
Thats the ledge it was alot easier in the dryer morning. It was raining while we were wheeling so it was just bad.
poser shot
Hatch love
Door love
Rocker love
Out of the woods.
Lesson learned
Never take girls wheeling in the rain.
This was my emergency fix for my oil pressure sensor literally splitting in half. I thought I popped the motor. 0 oil pressure and a huge cloud of smoke that was great!
threw a gauge on it
I am actually getting 30-80 psi oil pressure so I'm not complaining at all.
Getting swampers and welding the rear soon
Got some swampers
That one is the worst the others are okish. I bought them for the rims, all I can say is holy ****ing road noise.
Cut the fenders a bit more
Went to a local spot an had an ok time
Went to my buddies land and got it dirty
Also I have welded the rear axle and am digging it
Question for you guys
Say I have $500 to spend on my rig,
Do I
Do a ax15 swap and a zj steering setup?
Better tires?
Control arms and hiem or one ton steering?
Or some better firm valved shocks and shock hoops in the rear? An then steering?
I'm leaning towards the ax15 swap
My aw4 is starting to get bitchy it needs a torque converter and seal
yj brake lines (15 each at parts store)
zj gas tank skid (junkyard $20)
v8 zj steering (junkyard $25)
bumpstop
5150s
Nope my buddy said I couldent climb up that so I had to.
I don't know if I want to go straight to Hiems or do the v8 tie rod?
Or am I over thinking?
I need a new drag link so at that point the Hiems are $250 shipped the v8 stuff is $173 new kinda close
the v8 tierod you can easily get from a junkyard for $20
I'd spring for better tires those look like poop.
This is a plan!
I don't know what tires I want to rock.
Mtzs rock but are expensive
I like the swampers but god dam are they annoyingly loud as shit.
I may be getting some 33x10.5 or 32x11.5 boggers if my coworker is right.
I'm going to imagine road noise will be worse.
Mtrs are nice but they are expensive
Same with km2s.
