RWKHausSupply
- yorba linda, Cali
Thats right, you wont find them for less, or faster delivery.
Pricing only good till sold out or Christmas!
Yukon (Lifetime warranty) - 550$ shipped
RCV (Lifetime warranty) - 999$ shipped
USA Standard (one year warranty) - 375$ shipped
RCV Performance Ultimate CV Axles simply replace your Jeep YJ, TJ or LJ's weak Dana 30 U-joint axle shafts with a high-strength constant velocity design. Tests prove Ultimate CV Axles to be twice as strong as OEM Jeep axle shafts, and they're just as tough at a straight angle as they are at extreme angles – where U-joints are weakest. Ultimate CV Axles also eliminate U-joint binding to allow smooth transfer power to the ground. Even if you have big tires and big power there are no worries. Ultimate CV Axles are low maintenance and operate with a smoothness you can feel – whether off road or on the street. And we back it all with a "No Questions Asked" limited lifetime warranty.
Yukon front 4340 Chrome-Moly replacement axle kit for Dana 30 ('84-'01 XJ, '97 and newer TJ, '87 and newer Wrangler) with 27 splines. Yukon 4340 Chrome-Moly axles provide up to 50% increased strength over stock axles for use in extreme performance applications with large tires and high horsepower. Yukon's 4340 axles are manufactured using the latest technologies and the highest quality materials to ensure high strength and long life. This kit comes with inner & outer axles for both left and right sides along with Dana U/joint. Limited Lifetime warranty covers manufacturing defects and axle breakage for as long as you own the vehicle. This warranty is not transferable to another party. "No Questions Asked" replacement for first warranty return, however Yukon reserves the right to either replace axle or refund original purchase price after the first warranty claim.
Ten Factory front axle shafts are designed for original equipment tire sizes and moderate off road use. When you upgrade your Jeep or 4x4, you need to upgrade your axle shafts. TEN Factory designs our front axle shafts to maximize strength and durability, and back them with an exclusive TEN-Year Replacement Warranty.
4340 Chromoly Material High strength and ductility
Dual Heat Treated puts the strength precisely where designed
Torque Equalizing Diameters helps eliminate u-joint failure
Kit includes a pair of:
Inner Axles (stock 27 spline)
Outer Axles (stock 27 spline)
Spicer 760 Ujoints
& full circle clips
Yukon (single cut to length STRONG axle - lifetime Warranty) - $150 shipped
Ten Factory Axle Kits come with a 10 yr warranty on axles!
Rear Axle Kits feature 4140 chromoly material, TEN Factory engineers each axle and kit for a specific vehicle, and are a bolt-in performance upgrade.
See significant strength increases, due to Chromoly over mild steel.
Kits are complete with left and right axle shaft, axle bearings and seals, and wheel studs.
Note: Bearing is not pressed on due to Semi-universal application. If you need a retainer with the axle kit, please specify which application. Most any local machine shop can easily press the bearings on for minimal charge.
Ten Factory Axle Kits come with a 10 yr warranty on axles direct from Ten Factory.
_____________________________________________________________________________________
Yukon 4340 Chrome-Moly replacement rear axle for Dana 44, 30 spline (26" ->34" CUT2LTH) TRIPLE DRILLED. Yukon 4140 Chrome Moly alloy axles offer a strength increase over stock while retaining a low cost. Yukon 4340 Chrome Moly alloy rear axles come with a limited lifetime warranty against manufacturing defects. This axle is for use in 2.750" brk' offset applications. Fits TJ, XJ, MJ JK & WJ rears.
FOR THOSE THAT DO NOT KNOW OR HAVE NOT ORDERED IN THE PAST FROM RWK HAUS SUPPLY
WE HAVE THE BEST PRICES, BEST COMMUNICATION, BEST PRODUCTS, AND FASTEST SHIPPING
YOU WONT FIND BETTER CUSTOMER SERVICE
Pricing is plus tax for Wash. and Tenn.
Dana 30 (both high pinion and low pinion)
Ten Factory (10 Year warranty warranty) - 515$ shipped Dana 30 (both high pinion and low pinion)
![rcvfull.gif](/proxy.php?image=http%3A%2F%2Frwkhaussupply.com%2Fpicts%2Frcvfull.gif&hash=2be46af8bac8c6b88400d9df61535ace)
![RWKYAW24110.jpg](/proxy.php?image=http%3A%2F%2Frwkhaussupply.com%2Fpicts%2FRWKYAW24110.jpg&hash=9585cfb468873658d1ee096026c06041)
Spicer 760 Ujoints
& full circle clips
![RWKTENFACTORYMG22148.jpg](/proxy.php?image=http%3A%2F%2Frwkhaussupply.com%2Fpicts%2FRWKTENFACTORYMG22148.jpg&hash=acd3a347e2c4c174df873194cdd65248)
Dana 44 rear 4340 Axles
Axle retainers add 10$.
Ten Factory (10 yr warranty) - $299 ShippedAxle retainers add 10$.
![TFdana44.jpg](/proxy.php?image=http%3A%2F%2Frwkhaussupply.com%2Fpicts%2FTFdana44.jpg&hash=0bc6a11687bf73fbe7fd3103d944b296)
![YAD44rear.jpg](/proxy.php?image=http%3A%2F%2Frwkhaussupply.com%2Fpicts%2FYAD44rear.jpg&hash=5720a09902599c1791193656b0bdd9b1)
