xj88superjeep
- NJ
Actually, SM is the same as SL, as it recently replaced SL as the highest rated oil. Even for formulations that stayed the same. Additionally, the diesel oils are also SL and SM rated for gasoline engines, and CJ-4 is the current best diesel rating.. The biggest factor, however, is NOT found on the label or in the API. That is the level of zddp. it can only be found in the PDS or MSDS online. A higher API rating is just a bonus that higher zddp oils have.Ecomike said:The simple answer is that if the bottle has API SM listed anywhere on the label it is probably no good for our engines. IF the SM is no where on the label, and SL is on the label, or CH is on the label if it is diesel oil, then you may be OK.
If it does not have SL, or CJ, but has CH on the label and is a diesel oil it is probably the best you can buy as far as zddp content is concerned.
So if you want ZDDP, be careful of the following:
NOT ALL HIGH API RATED OILS HAVE ZDDP
however
All oils with alot of zddp usually have the best API ratings.
