- Bakersfield, CA
I guess it depends on how you look at it. Bend the arms, weaken the outer wall of the arm due to the bend, and have great clearance. Or, you run arms capable of taking abuse and don't worry so much about the clearance. I can see benefits to both.
I know you've been in the game long enough to know how well clayton's arms hold up...
If you look, you'll see that the upper arm mounts are at the bend, and so act as a gusset, so no potential weakness there........not an issue, at all.
Yes, I've been around a long time, and if you read around you'll find that I have never been a fan of the Clayton LA kit because of the ground clearance. I could care less how they hold up. Because of ground clearance, I'm not a fan of long arms in general, except for the TnT kit which is high clearance, and some of the nicely done custom fabbed setups.
I have a principal that I won't to modifications that decrease performance in one way to gain performance in another way......that is a waste to me. So, based on that principal I won't install long arms or any other modification that decreases ground clearance when other options are available. Clayton is a good guy, and makes good stuff, but his long arm kits are much more popular in the east, you hardly see them in the west where we crawl so much and ground clearance is king.
Yep, we all have opinions, and I'll try to back mine up with reason.
