xj radiator conversion
waynebosz
I'm ready to install the new '92 radiator in '87 4.0L Cherokee but the top plumbing connection for the transmission cooling lines are different. The bottom line fitting is ok. I read Bob Mock's article on the conversion to use original fittings from old radiator. My question is: Can I remove old fittings from '87 rad without damaging because it has a lock type nut over fitting that looks like it might be welded or it's just difficult to remove? Can I remove the fitting from the '92 rad or is it welded in? Or just take a pipe wrench to remove? This is the only step that is stopping the project.
This forum is for technical issues regarding the forum software and website specifically.
You'll have better luck asking your question on a tech forum. :)
But Isn't this the support forum?
:D
sorry,, j u s t c a n t s t o p ..
