XJ/MJ KY/TN line
kyjeepxj
SE Ky
I have for sale an 87 XJ with a 4.0 5spd 4x4 runs strong shifts good. I have the dana 30 removed started to put lift and different axles on it from my MJ. The MJ has a 2.5 5spd 4x4 runs rough trans and transfer are good needs clutch master or slave not sure which and fuel pump. Body is rough and bed is cut. Has Rustys 6" coils Rustys upper and lower control arms Rustys HD Trac Bar and Bracket. Spring over on the rear with Rustys add-a-leafs. dana 30 and 35 with 3.73s welded. 35 has new bearings and seals only a few rides on them. 33" swamper TSLs. I need these out of my yard $400 each or $700 for both
