xj idles irraticly and dies sometimes at idle
beechya475
wisconsin
i have a 1988 jeep xj with the 4.0 liter motor and it will ldle up and down to where it will almost die and other times it will die. when i am driving it will run great and not spit or sputter. it is just at idle or when i come to a stop and push in the clutch it will die once i a while. any ideas would greatly help. thanks aaron
EGR Valve. Just replaced on my 89 which was doing exact same thing. First check all the vacuum lines. If they are connected, I found I could disconnect the vacuum line at the EGR valve and it would run fine, but when I hooked up the EGR, it would stall at idle or when braking. If I remember right, my Haynes manual had decent troubleshooting for that.
Good luck,
Greg Fowler
'89 Cherokee
'97 Wrangler
'50 CJ-3A (in pieces around the house)
