WTB: a upper passenger control arm
Skipper51
I need to get a passenger side upper control arm to weld on to the truss of a D30 that I just purchased.
I have check online but did not see anything that really seemed right to me.
Any help is greatly appreciated. :eyes:
When i go to install the axle I want everything in place so it just slides on as quickly as possible.
you want the arm or the mount?
Two tabs on the axle and a new upper control arm with two joints or a joint and a bushing, and that uses bigger bolts.
Went with this, Control Arm Bracket - RE9986(Thanks Eric.) I'm a guy who does not know how to weld yet so this seems the simplest way to go. I will just weld it to the truss and it should be good. My first weld since High School wish me luck I'll need it.
Come On Down To Sacramento If You Want A Hand. I Have A 220 And Scrap To Practice If You Want.
I Would Offer To Go Up But I Dont Know When I'll Be Able To Get Away. Maybe Friday In Two Weeks?
Thanks Josh , as I will be installing the axels 3/29 up here and will need to have it ready to just bolt in. I have a couple of buddies here and yossarian19 is coming over from Banner Mountain so it needs to be ready to go. The plan is to have both axels in before lunch.
that wont happen! lol. count on 2.5 hours for the rear and about 5 hours for the front.
it always seems like it will be less but things always happen and make it take longer .
Man I hope your wrong. I am doing in a shop with a lift and air tools so I am hoping that shaves some time off your estimate.
oh yah that will.
