Sarge
- St Louis, MO
Sorry if this is in the wrong spot...feel free to move as needed.
Just recently picked up an older motorcycle (1983 Shadow) for real cheap. Got it running and now it's time to fix/personalize. Stock bars are way too close for comfort. Was thinking about making a set of drag style bars out of solid brass rod. I really dig the look of brass.
Current bars are 7/8" and knurled at the bolt down area.
Thoughts/plans:
1" bars necked down for the clamps to 7/8" and knurled. The necking down will be as close as possible to the clamps so it appears that the bars are 1" all the way. Most likely will want to tip the outward ends of the bars towards the rider for comfort. Controls to be trimmed down to min.
Possible problems:
How heavy?
Will the bars be strong enough? Especially at the necking down spot?
Can a solid brass bar be consistently and/or safely bent...say 10-15 degrees?
I may end up having to add in some rise for comfort. If so I'm assuming it would be safer to cut and weld. Without measuring we're probably looking at a rise between 2-4" into brag bars. Not broomstick style but out straight for approximately 1/2 the distance and a bend of approximately 10-15 degrees. If you know motorcycles Magnas and Marauders run this style.
Sarge
Thoughts/plans:
Possible problems:
How heavy?
Sarge
