sourblufff
- Germantown, MD
I recently installed WJ front seats in my '98 XJ. As this swap was so easy even I didn't screw it up a write up probably isn't needed but pictures can't hurt. This works off the fact that the WJ and XJ seats attach to the sliders in the same way. So basically all you are doing is swapping XJ sliders onto the WJ seat.
First remove the XJ seat. I found it easiest to start by sliding the seat completely foward and remove the rear fastners (18mm nut, 13mm bolt)
Next slide the seat all the way back and remove the front fastners (2 13mm bolts).
Now get the seat somewhere you can work on the bottom. I found that sitting it in the rear cargo area places it about the perfect height. It should look something like this.
The slider (which is actually 3 pieces, two rails and an adjustment handle) is attached to 4 tabs on the seat. This should give you an idea.
Remove all four nuts (13mm) attaching the slider to the seat. Here it is with one rail removed.
After you have the slider removed from the XJ seat, remove the slider from the corresponding WJ seat. Now install the XJ slider onto the WJ seat. I found it easiest to attach one rail first. Start by putting the rear stud in place (star in pic below). This will align the front stud such that it only fits the correct way. Make sure the sliding mechanism (gold in pic below) faces the inside. Now set the other slider into place but don't tighten. This gives you wiggle room to attach the adjustment handle. It mounts over two tabs (triangle in pic below) on the sliding mechanism of each rail. Then tighten all four nuts.
Now install the seat in the jeep. Set the seat in place using the rear stud as a guide. Start with the front bolts. This will align the seat properly. Now tighten the rear nut/bolt.
I've had the seats in for about 2 weeks now and love them. They do sit a bit higher than the XJ seats. But even at 6'4 I am fine with the seat just slightly reclined. The are considerably more comfortable and the head rest is now tall enough to be useful!
