IntrepidXJ
NAXJA Member #647
- Grand Junction, CO
Got these tail light boxes from full size xj gear with Incandensent lights
http://fullsizexjgear.com/Fullsizexjgear boxes.htm
Got everything wired up using a Drawtite converter box, and I'm still having a little problem.
When I use the turn signal and brake light seperately, they work fine. However, when I have the brakes on and then turn on the turn signal, the light goes off (or reverts back to the tail lights if they are on).
The wierd thing is, is that if I turn on the emergency flashers while the brake is on....it works just fine.
Any suggestions?
We have double checked all connections. BTW- I have a 92 XJ
Thanks in advance
Any suggestions?
Thanks in advance
