I had brake light issues with Auxito LED bulbs. That was the first indication of my brakw switch. Second indication was one side being out completely and the 3rd brake light not coming on when pedal depressed, which ultimately became all the brake lights not working.
I suspect a combo of both bulbs and switch. I ended up pulling the LED bulbs for the brake lamps and installed xenon or krypton bulbs from rallylights.com. Brighter than factory, brighter than LED. I’ll have to check my records for a part number, but it wasnt a 3156/57 bulb.
The smd turn signals are nice, and so are the clear lenses/switchbacks up front. I run them light DRLs/inclement daytime weather lighting or in construction zones in combination with my flood cube lights at the stock fog position. All ebay stuff. The clear lenses are stamped upside down but fit and quality are decent given the price.
I did end up replacing the switchbacks in short order, the cheap Auxito bulbs i bought originally went out but still worked for turn signals and mechanic failed me on inspection for no marker lights
The dogbone style Amazon LED headlights are fan-friggin-tastic and worth every penny of the $25 i spent on them. So much so that i really didnt need to add auxilary lighting…but its a jeep after all lol
Dash lighting was a pain in the richard. I only did it FTFOI because i wanted red backlighting. The bulbs are cheap, plastic wedge bases with a single led on hair thin leads. Easy to short out and polarity sensitive. You’ll be a master at dash assembly by the time you finish. Leave the shift indicator lamp alone unless you use a color other than red (hard to see the red indicator in the window on the bezel…tcase bulb in red is fine though). And dont expect them to dim anymore.
