I just wired up a new set of fogs and while I was at it installed a manual switch to the cooling fan. I used a 25 amp fuse with it and all I did was tap a positive line off a relay into the positive line going into the fan.
I tested it out for a few seconds to make sure it worked. I was just playing safe with the 25 amp fuse
Nothing wrong with the setup? It wont confict with the stock automatic control?
