- Roanoke VA
"When" I go winch shopping I'm going to get another Warn 8274. I had one and let it go with the truck, wish I had it back!
emr1101 said:the other two you mentioned ive heard bad about. DEFINITLY go for the warn M8000, if i could do it again I would
emr1101 said:i have a tmax ew9000. cheap winch, powerful but ive had a good amount of problems with it. Seems to be poorly built, i had frame mounts crack on it. Id stay away from them, the other two you mentioned ive heard bad about. DEFINITLY go for the warn M8000, if i could do it again I would
Deadman 94 xj said:Thanks for all of the replies. I can't order anything untill friday but so far the Superwinch sounds realy good. From searching I can't find much bad about it.
I'm not sure if I can mount the 8274, I have heard that it is "the best" from other threads by different people. The bumper I'm using has plenty or room to mount but I'm guessing that the holes won't line up with the predrilled holes.
Is that the only difference or is it the way that the winch is clocked that makes it different?
HaleYes said:I'd say your mounting surface is likely not level if your cracking the mounts. Most winches would do the same if they're not mounted on a flat surface.
What is it?techshooter02 said:![]()
this is the winch that has saved my ass more times than i can count deep mud to steep hills...and cheep too.
Nevada City Sparky said:What is it?
