Euology101
- NYC
For sale: 1999 Jeep Cherokee XJ, with just under 150,000 miles. I purchased this a year ago from a gentleman in Virginia, and have since done much more work on it, as it was going to bring me to California this summer, but my plans have since changed. There is every little rust on this, as it was garaged, there is a little surface rust below one rear window, as well as a few spots on the underside, but overall, this is a VERY clean Jeep - Photos will tell, and ask for any more photos you may want to see.
Motor: 4.0 straight 6
Front axle: HP D30 - 3.55 Gears
Rear Axle: C8.25 - 3.55 Gears - SOLID Diff cover
Transmission: AW4 Automatic Transmission
Transfer case: NP231J with an Advanced Adapters SYE
The Good:
Exterior:
- ARB Front Winch Bumper - http://store.arbusa.com/ARB-Deluxe-Bar-Jeep-Cherokee-XJ-1997-0-3450080-P3326.aspx
- Quadratic Q9000 Winch - http://www.quadratec.com/products/92122_2010_07.htm
- PIAA Driving Lights - http://www.quadratec.com/products/97041_1X_PG.htm
- Kevins Offroad Roof Rack - http://www.kevinsoffroad.com/cart/r...rack-92-xj-with-newerstyle-rails-only-p-1911/
- Hanson Offroad - Rear tire Carrier - https://www.hansonoffroad.com/proddetail.php?prod=JXJRTC-P
- LED Backup lights mounted inside the bumper - Completely concealed, but when turned on its as if you have headlights in your rear bumper.
- 31x10.5x15 tires - Procomp AT's with about half tread a BFG KO2 Full size never used spare. - Includes a set of wheel locks
- 15" Blackrock steel wheels
- Upgraded headlight harness - Can handle overpowered bulbs
- H4 conversion Headlights - replaceable bulbs
Engine:
- New BrownDog Motor Mounts with Rubber Bushings - http://browndogindustries.com/CU2572-0K2-Jeep-Cherokee-XJ-Motor-Mounts-Rubber.aspx
- K&N Cold Air Intake - http://www.knfilters.com/search/product.aspx?prod=57-1518
- Jet Chip - http://jetchip.com/shop/chips-modules-programmers/dodgejeep-module-stage-1-4/
- New spark plugs - 1 year old
- New Spark plug wires - 1 year old
- New distributor cap - 1 year old
- Replaced Exhaust Manifold - these are known for cracking - 8 months old
- Bosch 784 Injectors - 6 months old
- B&M Transmission Cooler
- Dynomax Stainless steel Catback exhaust - Inspected Cat at time of install, and was clean.
- Replaced Power Steering pump & pulley, with High and Low lines replaced - 1k miles ago
Drivetrain:
- D30 front axle - Replaced oil less than 10k miles ago - LubeLocker Gasket -
- C8.25 Rear Axle - Replaced Oil less than 2k miles ago - LubeLocker Gasket - SOLID Diff Cover
- Rear Driveshaft - all new U-joints, balanced, painted at time of SYE install, less than 8k miles
- Transfer Case - Oil changed when AA SYE was added.
- NP231J - Boostwerks - Shift linkage installed - http://www.boostwerksengineering.com/231-HD-Shift-Linkage-Auto-Trans-_p_25.html
- AW4 Transmission - Oil Changed about 15k miles ago
Suspension:
- Rubicon Express RE1310 - 4.5" Coil Springs - less than 500 miles - New rubber Isolators
- OME 3.5" Leaf Springs - with brand new Moog Bushings
- RE2700 Grease-able Lift Shackles
- HD Offroad - Shackle Re-locators - These put the shackles at the correct angle, for more articulation, and smoother suspension. http://hdoffroadengineering.myshopify.com/collections/frontpage/products/xj--shackle-relocation-kit
- Bilstein 5100 Shocks - front and back
- Rough Country - Control Arm Drop Brackets - This puts the CA's parallel with the road for more articulation, and a much smoother front suspension.
Steering:
- Zj upgrade Tie rod and TRE - Less than 1k miles
- JKS Adjustable Track bar - http://www.quadratec.com/products/16007_001_07.htm - rebuild Johnny Joints less than 500 miles ago - new bushings & C-clips
- Rebuilt Durango Steering Box - Not yet installed
Interior:
- B&M Transmission Temp gauge installed in Center console
- Kenwood Head unit with Bluetooth, and Microphone for hands free calls - Works through the speakers
- Rockford Fosgate 12" subwoofer with a 500w amp under the rear seat
- All speakers have been replaced as well, I can't remember the brand off hand.
- Sagging headline was re-done with new material, looks like new
- Quadratec Floor mats: http://www.quadratec.com/products/14254_7001_07.htm
Now for the bad, which really is not that bad:
- Leaking Oil Adapter - If you know this jeep, you know how common this is - I have the replacement o-rings as well as a custom made torx head tool for removing the adapter - just haven't gotten around to doing this. This is a small leak, and I've never had to top off the Oil between oil changes.
- Lower radiator hose leak - Hose is old and brittle - I was going to replace the water pump, both upper and lower hoses, along with the thermostat - so I have all parts, and all gaskets to go with the sale. - This is an intermittent leak, and tends to only happen when driving a few miles on a cold start - top up the coolant, and its a non-issue.
- Power Steering pump seal - This is leaking as well, which is why I purchased the Durango steering box to replace it - This is ready for swap, and requires nothing more than a pitman arm puller and some basic hand tools - top off the oil here and there, and its not an issue.
- Fuel pump - The all to familiar check valve has failed. What this is means is that the fuel flows back into the tank when you shut the car off. To get around this, you have to prime the engine (turn key to acc position for 3 seconds) a few times, and it starts right up. This is a well known issue, and the work around even has a nickname "poor mans prime". To fix this, you would need to drop the fuel tank, and replace the pump with a BOSCH fuel pump. This is about a $200 fix.
Jeep is currently located at my shop out in Plainview, Long Island, but I live in Queens, I can bring it home and show it in Queens, or I can meet you at my shop in Long Island, whichever is easier.
I am asking $7,000, the accessories alone are worth 3k. Compared to other XJ's in the area this is one of the cleanest, and probably one of the lowest miles. I will discuss offers, but I'm in no hurry to sell, as I have a daily driver, and I can use this when the weather is bad. I will not entertain offers, so please do not ask. This is being sold as-is, I just have to say that so that you understand there is no warranty, no implied warranty, nothing. Do not contact me if you do not have 7k in cash on hand, no checks, no shipping, no scams, no games, no tire kickers. It is currently registered in NC, and will need a NY inspection, if you plan on registering in NY.
If you would like any more photos, or a video of the engine running, I will be more than happy to provide you with one, just PM me.
[/url]IMG_1920 by Titocci, on Flickr[/IMG]
[/url]IMG_1910 by Titocci, on Flickr[/IMG]
[/url]IMG_1911 by Titocci, on Flickr[/IMG]
[/url]IMG_1912 by Titocci, on Flickr[/IMG]
[/url]IMG_1919 by Titocci, on Flickr[/IMG]
[/url]IMG_1916 by Titocci, on Flickr[/IMG]
[/url]IMG_1917 by Titocci, on Flickr[/IMG]
The Good:
Exterior:
Engine:
Drivetrain:
Suspension:
Steering:
Interior:
