premoxj
- San Diego, CA
i have another winch, this thing is taking up space on the garage floor...price is OBO. its never been used and still in its original package. I will entertain interesting trades of course
$700
http://www.warn.com/truck/winches/src/m6000sdp_multimount.shtml
WARN M6000 SDP SHORT-DRUM PORTABLE
The perfect winch for light sport utility vehicles</B>A short-drum portable winch for light sport utility vehicles, the 4.8 hp M6000 SDP provides plenty of pulling power, can be mounted single-handedly, and stores in a snap. This compact winch comes complete with handle/mounting system for a Class III 2" receiver, hawse fairlead, remote control with 12' lead, free spool clutch, 50' of 5/16" wire rope and power lead with Quick Connect plug for the front of the vehicle. The perfect companion when you take your rig off-road, hunting, fishing or skiing.
This Kit includes winch with built-in carrier, remote, power lead with Quick Connect plugs for front of vehicle and hawse fairlead. Front receiver and rear power cables sold separately.
M6000 SDP SPECS/PART NUMBERSPart Number: 39116 (12V) Rated Line Pull: 6,000 lbs. (2720 kgs) single-lineIntended Use/Application: Vehicle Recovery / For Trucks and SUVsMotor: 4.8 hp, Series WoundRemote Control: Remote, 12' (3.7m) lead Geartrain: 3-Stage Planetary Gear Ratio: 156:1Lubrication: Aeroshell #17 Clutch (freespooling): Sliding Ring GearBrake: Automatic Direct Drive ConeDrum Diameter/Length: 2.5"/5.0" (26.4cm/13cm) Weight: 72 lbs. (31 kgs.)Wire Rope: 50', 5/16" diameter (15m, 8mm diam.) Fairlead: HawseRecommended Battery: 650 CCA minimum for winching Battery Leads: Front heavy-duty 7.5'/2.2m with quick connect plug Finish: Argent Powder Coat
12V DC PERFORMANCE SPECSLine Pull
Lbs.(Kgs.)Line Speed
FT./min(M/min.)Motor
CurrentPull by layer
layer/Lbs(Kgs.)048.5(14.78)85 amps1/6000(2722)2000(907)23.7(7.22)175 amps2/5460(2477)4000(1814)12.9(3.93)360 amps3/5000(2268)6000(2722)10.0(3.05)465 amps4/4670(2118)
$700
