RWKHausSupply
- yorba linda, Cali
Thinking about selling my Rock98 Winch. With moving in to Jeepspeed I dont for-see ever needing it..
It is about 2 yrs old. and used maybe a dozen times to pull the jeep onto the trailer when it was not running. Still awesome condition.
New they are $1050-1200.
http://www.amazon.com/Superwinch-16...&qid=1386185116&sr=8-2&keywords=rock+98+winch
Wanting to get $650 for it.
This is a smaller Overall outside sized winch, with more power then most larger winches, and rated at 9800 LBS. & Fast speeds.
Also, lighter then most others.
Includes the synthetic line and ready to go.
Specifications
Rated Line Pull 9,800 lbs (4,445 kgs)
Motor Sealed 5.2 hp (3.8 kw) Series Wound
Gearing 2-Stage Planetary and 2-Stage Spur
Gear Ratio 148:1
Solenoid Vented, Sealed Submersible Solenoid with 3-Year Warranty
Clutch Free-spooling Clutch/Pull and Turn
Brake Automatic/100% Load Holding (outside of drum)
Rope Synthetic Rope 3/8” x 50’ (9.5mm x 15.24m)
Hook Yellow Heavy Duty/Clevis Pinned/Latched
Fairlead Anodized Blue Aluminum Hawse with Engraved Superwinch Logo
Remote 15' Sealed Ergonomic Hand-held with Coiled Cord
Dimensions 20.22” L x 6.2” D x 10.95 ”H (513.60mm L x 157.50mm D x 278.15mm H)
Drum Diameter 2.5” (63.5mm)
Drum Length 4.75” (120.65mm)
Mounting Bolt Pattern 6” x 4.5” (152.4mm x 114.3mm)
Installed Weight 62 lbs (28 kgs)
Warranty Limited Lifetime Warranty/3-Year Electrical
Line Pull: 0 lbs 75 Amps Motor Draw / 62 FPM (18.9 MPM) Line Speed
Line Pull: 9,800 lbs 445 Amps Motor Draw / 4.8 FPM (1.46 MPM) Line Speed
"What is your secret?" - that's what everyone will be asking out on the trail. How can you pull at max power and get back on the ride so fast? The answer is your Superwinch Talon Rock 9.8. With 9,800lbs of pulling power on 50' of rope, you'll be pulling in the "Power Zone" - the first two layers on the drum. Higher layers rob your winch of power - with the Rock 9.8 you won't need to spool out extra rope to get at it.
9,800 lbs of pulling power in a small, lightweight package! Weighs 28 lbs less with Dyneema™ synthetic rope, 4” narrower for smaller modified competition vehicles, Free-spool knob rotates in 45° increments for custom applications, Industrial grade, over-sized, safety yellow latched hook and 3 solenoid box installation options; Offset (solenoid over motor, as shipped), Centerline (solenoid over drum, kit included) and Competition (solenoid remotely mounted, kit included). Note, mounting bolt pattern is 4 inches narrower as compared to the standard Talon (6" x 4.5").
Superwinch synthetic ropes are genuine AmSteel-Blue™ with Samthane™, a special coating to help resist abrasion. The raw material in AmSteel-Blue™ is made from genuine Dyneema® SK-75 HMPE fiber, "which is the worlds strongest fiber™" made by Samson Rope Technologies.
AmSteel®-Blue is a torque-free 12-strand single braid that yields the maximum in strength-to-weight ratio and, size for size, is the same strength as steel—yet it floats. AmSteel®-Blue outlasts wire 3:1, making it an excellent wire rope replacement. It has extremely low stretch and superior flex fatigue and wear resistance. Average strength is 19,600 lbs. and minimum strength is 17,600 lbs. Elastic elongation is only 0.96% at 30% of the break strength.
Specifications
Gear Ratio 148:1
