Hi Guys;
I am getting a very good deal from a guy who is parting out his 8 inch rock ready kit, all i am buying is his crossmember and the LCA and the UCA's. So my question is would it work on the 5 inch lift that i have.
It would work fine. You probably won't want to use the front cradle things that mounts on the front axle though. Just so you know, normal UCA's work fine with the kit. If you don't use the cradle thing, you can't use the Skyjacker UCAs (a good thing in my opinion because the heims will drive you nuts), but you can use some others. I use RE fixed UCAs. The subframe is very strong and is a great addition to the cherokees unibody construction. Hope that helps.
