L lilwezel NAXJA Forum User Location windsor,ontario,canada May 14, 2003 #1 in my 97 wrangler. it seems the driver front went bad and i new a new one. i do have the o3 laying around and if i can use it i would lke to.thanx
Z zjmike NAXJA Forum User Location So Cal May 14, 2003 #2 The biggest issue you are going to have is the 03 Grand Cherokee uses a 5x5 bolt pattern, so it will not match the 5x4.5 of your XJ. I also think the unit bearing is spaced away from the knuckle differently.. You might check with MJR on that, he would know..:anon:
MJR NAXJA Forum User Location Costa Mesa, CA May 14, 2003 #3 Mike is correct. WJ hubs are 5 on 5" bolt pattern compared to a XJ/YJ/ZJ/TJ which are 5 on 4.5". For a 97 TJ you can use a hub from a 90-98 XJ, 90-95 YJ, 93-98 ZJ, or a 97-98 TJ. These should be interchangeable.
