- Gassaway TN
So I could get some parts from his 4.2.:shhh:
I thought about this a while back when mine started breaking.....True, but you don't know what the mains and journals have been turned that way.
just swap to propane! much cheaper for you and easier to deal with.i wonder if something that simple would fix mine but i dont want to spend any more money on my carb, i want EFI!
GOOD LORD! where are you pricing your propane stuff at? i can get you propane stuff for ALOT cheaper. with a tank. ive got a good friend that works for a forklift repair shop that gets propane stuff ALL the time. hes got tanks just laying around.not sure if you have done the swap but a propane setup from the ground up is over 1K plus i would have to fix my current engine to get it running right
and fix my valvetrain and whatever else is F'd up in my block and head too right?
the conversion i saw was a kit for $700 without tank and i thought they were in the couple hundred range, making it close to a 1k upgrade and then fixing my engine and getting a tranny.
thanks for the .02 256OF (its not unappreciated) but i'm going to stick to pump gas
TRT: the engine and wiring, what info on it? year make model of donor if you got it?
FINALLY!!! DOWN WITH CHEVY JUNK!88-95 5.0 Ford FTW! :yelclap: :shhh:
