srmitchell
- Mckinleyville (Humboldt) CA
Hey dudes. I won't bore you with my complaints about how my rig only manages 12mpg, but really... wtf. I'm looking for answers, and help.
Don't tell me to buy a honda. I have a Dodge dart which manages 27mpg, all day long. This is about range for expedition travel.
I use my jeep for travelling- I like rock crawling, but I usually only see dirt roads, rocky trails, and long distance backroad travels. I love exploring the redwood coast where I live, but the geographic distance between attractions is huge, so I need to ind out how to make this thing have a longer range.
2001 xj- 4.0, AW4. 190,000 miles.
33inch kevlars, 4 inch long arm... Lots of armor, but no roof racks or anything. Weighs 4200lbs.
4.56 gears... Only engine mods are an AFE intake, Flowmaster 40 dumped at the axle, 4 hole grand caravan injectors, 60mm throttle body.
I hate the aw4, and want to swap it for a NV3550... Im sure having a manual would boost my mpg average...
Any luck with the Banks header? (I have pre-cats).I tried electric fans once, two stock 97 fans. It worked, but I had a chronic issue with the fan controller and I once started overheating because of the bad controller. That spooked me and I went back to a clutch.
I have run BG44k twice in 2,000 miles. I run rotella 5w40, and I have changed the spark plugs in the last 15K miles I think.
I have never pulled the fuel pump to look at the filter... Maybe I should do that? 190K and 16 years of build up? How about the timing chain?
I'm sorta at a loss. I drove 70 miles to a coastal town north of me this weekend. I clocked 85 miles before I topped off my tank... It took 6.8 gallons for a whopping 12.5 MPG.
I consistently, with ZERO variation, get 200 miles to a tank. That is shit! Any and all help is appreciated. I know, I know... XJ's suck fuel... But what if I need to go somewhere long distance, and need the range? 200 isn't enough, especially if you must drive far to, and from a trail, where mileage will be even worse.
The thirsty junk-
Redwoods by Sean Mitchell, on Flickr
The thirsty junk-
