cloudswimmer
- So.Cal.
Kejtar said:damn... I missed that part! (paint fumes must be getting to me). D35 and 35's is bad juju! Dont even THINK about it.
But Rusty said it would be Ok
cal said:35's with 4.56 does suck goat balls though, compared to 4.88.
x2 im happy with 35's and 4.56. Though if i could i would have gone 4.88(8.25 rear end)JohnX said:A 6.5% difference sucks balls??? I have to disagree. There is no shortage of power or hill climbing ability associated with 35's and 4.56's versus 4.88's. You may think it feels better, but the difference is negligible.
cloudswimmer said:I do plan on 4.88's myself, but interesting note, I have quite a few Rick Russell videos, and a lot off the Jeeps in em on 35's are running 4.56's doing some pretty gnarly trails.Anyway on those Alloy USA Dana 30 chromoly kits do I want the 27 or 30 spline version, and how do I tell if I have vacuum disconnect or not?Its a 1996
Thanks
cal said:The 30 spline is stronger, you have to have the 30 spline locker to go with it of course. I did the 30, either will work.
cloudswimmer said:Ok thanks.Ryan had mentioned 27 spline would be fine, just wanted a little more feedback.I've got the powetrax in there with the stock shafts so I guess 27 spline it is?Then I keep my stockers as trail spares?Also still not sure if I need the vacuum or non-vacuum disconnect version of the Alloy's.Thanks for the help, I'm just learning this stuff.
cal said:Its the same thing, the disconnect version comes with an extra seal and a plate to delete the disconnect setup, but contains everything the non disconnect kit does and will work in both setups. Look at where the passenger side upper control arm mount is on the axle. If the axle tube looks like one piece from there to the diff, you have non disconnect. The disconnect axle will have a giant cast piece there.
ok, I rarely come out and say it, but this time I have to. Do you realize how hard was your post to reard with your punctuation and lack of capitalization and no paragraphs??pureaddiction said:i have an auto 6 cylinder with the 4.88 on 35" tires i didnt like it cuase the free way to me at 65 the rpm felt to high but thats just me.. but i did do well off road the only problem i have had in the front was going through a set of gears in two years... with the 4.88.... but in the rear with a dana 35 and the super 35 kit i wheeled the piss out of it on 35" tires and never had a problem in the rear.. but i am very light footed and dont hall bals up a hill. if i cant crawl it i wont do it.. how big is the difference in the rear dana 35 from 27-30 spline axles???? i wouldnt even ask this question and i am thinking of giving up cuase as much as i know the dana 35 sucks but i still am persitant to run it my main concern is not the housing or anything like that. its speciafically axles the strengh between the 30spline and the 27 spline from usa alloy.... i am thinking of just getting the bigger axles and just changin out the arb guts to accept the 30 spline....
cloudswimmer said:So does this look like a non disconnect?
Kejtar said:ok, I rarely come out and say it, but this time I have to. Do you realize how hard was your post to reard with your punctuation and lack of capitalization and no paragraphs??
(letters and numbers omitted for clarity)pureaddiction said:."..........".....-????.........
cal said:That is non disconnect yes.
pureaddiction said:ok i dont want to steal your spotlight away.. but i am in the same problem but with the rear cuase on my front i have been running the detroit tru trac with 4.88 on 35" tires and i beat the cra out of it with no problems same goes for the rear that had the supiror super 35 kit that has the 30 spline shafts wiht the detroit locker and i never had any issues with those either wit 35" tires.. but now on my new jeep i have usa alloy 27 spline shaft in the rear with 4;56 gears and arb air locker has any one run 35" tires with just aftermarket shafts and grears and locker and have any problems with 35's
pureaddiction said:thank for the the imput that is what i have been trying to get out of someone that has dealt with this irst hand .... eveyone just says dont run it they suck period.. and i know that but with my circumstances its all i have to use ..... so thanks again... well the housing is trussed so i hope that helps a little bit. but i guess we are just going to find out lol
x3. Especially if you have stroker power.:laugh:JohnX said:A 6.5% difference sucks balls??? I have to disagree. There is no shortage of power or hill climbing ability associated with 35's and 4.56's versus 4.88's. You may think it feels better, but the difference is negligible.
Want to race?
