- NE Indiana
03s and newer have a big problem with front drive shaft ujoints shelling out. The tolerances are way too tight and they cook pretty easily. I would bet this is the problem.
I'm going to take it to the local drivetrain shop and have them go through the shafts with me on their "pit", find what they think the problems are and then pull the stuff and have them replace/repair as necessary.
I do know that I have a bit of play in the carrier bearing and there is some slip in the splines on the 1st of the two rear driveshafts...I'll check the front out too.
I also think that the 600 cummins motor has so much power that I might be getting some axle hop too and may be fabbing up some traction bars...
my buddy has a 00 f350 7.3 powerstroke with 150k plus and has never touched his driveshafts either...with 88k on my 06 I'm a little bummed about it.
mac 'and i thought i wanted to lift a tow rig...no way' gyvr
