GrimmJeeper
- Gardena, CA
You've got plenty of room for a bypass. Jeepspeeds do it all day long. The only advantage of a coilover really is packaging and getting more travel.
x2
King/SAW/Bilstien are all roughly the same as far as piston design, shim design, functionality etc, they are dimensionally different so you can't really interchange parts, but to say they put "technology" in their shocks while the "others" don't is kind of misleading.. It all comes down to valving and customer service. No experience with FOA, never had one apart.
I would have to disagree with you Chris. Putting Bilstein with SAW and King is a bit misleading. King/SAW/Fox maybe but Bilstein has technology.....lets see if we can get some professional experience in here.
Bilstein is doing some cool new things with their shocks. Joel over at Bilstein is constantly testing and figuring out new ways to dampen, cool, and generally make shocks more reliable. Most of it is still in the prototype stages, and you won't see or hear about it. However you'll start to see them on race cars first, as that's where he's testing them all. I haven't seen Fox, King or Swayaway do anything "new" or "revolutionary" in shocks. If you want revolution, look at Bilstein's blackhawk... everything about that shock is revolutionary, and that technology is starting to leak over into their other shocks slowly but surely.
Put it this way, if I were building a race car, I'd want bilstein on my team. Simply for the fact that they strive to make sure you win, hands on.
I'm pretty sure the AGM Class 1 car that overalled at the baja was running a 2.5 shock up front... a 2.5... and never overheated.
I am just trying to help the op, blackhawks are bigger, have extruded aluminum bodies=fins=more surface area=better heat dissipation, but it still uses a piston, shims, oil and nitrogen, reservior/dividing piston and maybe a few little trick valves etc, and that is great that Bilsteins is working hard on being innovative, I totally beleive you and that is great. But the op asked about coilovers, and where to buy them. Personally I think he would be absolutley fine with any of the 4 big companies, King/SAW/FOX/Bilstein, the off the shelf shocks he will be running are all roughly the same, I think getting any deeper than that here would be superfluousNot trying to argue, just trying to stick on topic
, I highly doubt anybody on here is planning on running blackhawks on thier cherokee, although it would be cool to have that kind of coin. Glad you guys have had good experiences with Bilstein, but they are not the end all, pelnty of winning tt's run KING, FOX, Robby Gordon, Revolution, etc etc, but that is neither here nor there
Cheers
What makes you think that SAW/Fox/King are not doing the exact same thing? Don't get me wrong here I'm sure Bilstein makes a great product, but you seem to be clouded into thinking that they are the only ones trying to develop new things.... Bilstein is constantly testing and figuring out new ways to dampen, cool, and generally make shocks more reliable. Most of it is still in the prototype stages, and you won't see or hear about it. ....
fox... 4.4 5 tube bypass thats an amazing shock that i guarantee that they work as well as a blackhawk. alot of tt run fox. alot run blackhawk too.
I need Joel in here to get technical, but he built me and Tony a set of coilovers specifically for the front of our trucks. They have sort of a speed sensitive bypass instead of a position sensitive to firm up the shocks during rapid compression. This helps Jeeps especially to stay on top of the whoops. It made a night and day difference in Tonys bronco. I can assure you no other company has that technology... Yet. However Bilstein is still the first.
