I have a 93 xj and I need to change my front wheel bearings. Apparently it will either be a one-piece (rotor and all), or I can just replace the bearing sets. Which is it?
I shouldn't answer this because you posted it in the wrong forums but since it will get moved and since you are new...You have to replace the hub unit. THis is not the whole rotor and all but just the unit bearing itself. You can get them from crown for about 120 bucks if you know someone who sells crown parts.
