gptherezonlyone
- Wilmington, NC
Help, I'm about to sell this thing and buy something foreign.
Markm80521 said:first, second, third, fourth, fifth time CPS goes bad and on just unplug the connection (right behind the Valve cover) and then plug back in. When that stops working then replace it. I've been doing that for 20,000 miles now (about 10 times) and it won't die.
Kejtar said:Do carry a spare and be ready to replace it on the side of the road though if it does decide to die completely![]()
CPS for 89 cherokee , the '91 and up uses Wells SU 369 ($49.99)and carries the same warranty.If you are 91+, go to Quadratec and order a few. If you're 90 or older, it's OEMR only. I have three XJ's - 87, 88, 89, and no-one makes aftermarket CPS for them (damn.)
Kejtar said:ok.... if you didn't get the slight hint I was trying to relay I will come out and spell it out: Based on the location I don't know who would want to replace it on a hot engine anyways.....
So are you stating that the Computer is at fault. When you unplug the CPS, the computer then resets or learns the new signal. I'll have to do some more touble shooting, maybe find a good oscilliscope to see the acual signal. HMMM something to think about.Markm80521 said:Pssst..... Got an extra one. Know how to change it. Doesn't make since to change it since the handful of times that it seems to have died, you unplug it and plug it back in and the car cranks up like a champ and runs perfect for another 3-6 months.
Of course now that we've talked about it, it will fail completly next time I'm on the highway and I will blame YOU! All of YOU! NAYSAYERS!:flipoff:
ChuckD said:So are you stating that the Computer is at fault. When you unplug the CPS, the computer then resets or learns the new signal. I'll have to do some more touble shooting, maybe find a good oscilliscope to see the acual signal. HMMM something to think about.
Mine acts the same way, but I do know at times that I replaced my CPS. I was magnetized and I know it is really just a simple pickup coil. When they get magnetized obviously the copumter must be getting a false signal.Kejtar said:Well.. to throw the wrench in here it might not necessarily be the computer at fault. When my CPS was acting up, all I had to do was sit for about 10 ~ 15 minutes and then it would startup again on the first crank. So the amount of time that it takes to go out, pop the hood, unplug it might be the result of the same....
On the other hand, it is possible that there is a timing loop inside the comp that gets hung and deadlocks waiting for input or output and the wait just gets past a timeout that resets it and it is the same as the unplugging and plugging in of the CPS. Now to even complicate things, what if it is the CPS that causes the lockup and then when unplugged it resets both the CPS and the computer?One of these days I might be tempted to look at the logic used in the computer, although I have a feeling it will result in a major headeache.
