- Spring Grove,IL
Finish project consolidation. It's a long list.
Jeep
Bare minimum:
Replace oil pan.
Replace rear axle seals...again.
Wish list that should happen:
Replace rear axle shafts with all new seals, bearings and retaining plates, keep old stuff for spares.
Rear tire carrier/bumper/hitch combo.
New steering.
Wish list that I hope can happen:
Flat skid plate.
Control arms and track bars.
Tow rig:
replace hitch and add a few reinforcements.
fill propane
give entire rig a good look over.
Trailer:
New tires.
Bearings repack.
See if golf cart will fit on it.
mac 'got to keep working to pay for it all' gyvr
Have new oil pan
Have new shafts, seals, bearings, backing plates.
Ordered a new tire/carrier/bumer/hitch combo.
Ordered new resistor for blower to make it work on more than just "high"
mac 'now to find time to do it all' gyvr
Rebuild front drive shaft
New drag link and tie rod end
Install front tow hooks
New radiator, it's leaking!
Find some type of rear recovery point and install it. Let me know if you have a hitch you want to sell!
-replace drivers rear window with plexi-glass (both rears will match now)Tow rig:
-Water Pump or buy more coolant
-air up spare tire
Jeep:
-replace bent wheel (Done)
-confirm spart tools and parts are in jeep (Done)
-fix whatever my brother breaks this Sunday (well see if the stupid hub bearings hold up)
-clean the jeep, well see
both doneFix broken D300
Rebuild rear drive shaft
New list, why'd it have to get longer? :twak:
Jeep:
Install 231 - done!
Figure out rear drive shaft
Figure out front drive shaft
Install long arms - done!
Install coils - done!
Limit straps for front
Re-do bumpstops
Install new winch
Install longer front brake hoses
Install shocks - done!
Install track bar and bracket - done!
Added:
Adjust caster
Weld xmember brackets
Trans filter
Fill tcase
Tow pig:
Change oil
Install super mega killer hitch
Camper:
Install dedicated fuse block for the heater
Seal roof
Fix the jack mounting points
Rip out toilet and replace with a portable
both done
added
replace battery -done
get new CB mic
give the rig a once over -done
