Whatcha need to get done before Winterfest?
Fix the locker I haven't even got to use yet....:/
I saw that on IG. What happened?
Copper line on the seal housing separated from it. It didn't look like it broke off, it's gotta be a manufacturing defect.
is there an easier way to change the bushing?
My list for this weekend is
Front axle:
U-joints
hubs
pads
rotors
knuckles(drilled out for steering)
1ton steering set up
once all this is done im ready for WF.
done!
Install C4x4 Tow hook brackets and hooks(hoping they get here before Thursday), mount my spare 30" tire to make all match. Install factory battery hold down(current battery is larger than original one), fill gas tank. Other items as they come about.
ihscout "always doing things last minute" lover
Jeep:
Install 231 - done!
Figure out rear drive shaft - done!
Figure out front drive shaft - done!
Install long arms - done!
Install coils - done!
Limit straps for front - done!
Re-do bumpstops - done!
Install new winch -done!
Install longer front brake hoses - done!
Install shocks - done!
Install track bar and bracket - done!
Alignment - done!
Weld xmember - done!
Trans filter
Fill tcase - done!
Steering - done!
Tcase shifter - done!
Skid plate - done!
Fuel cell - done!
Ds u-joints
Tow pig:
Install transmission - done!
Change oil - done!
Install super mega killer hitch - done!
Camper:
Install dedicated fuse block for the heater
Seal roof
Fix the jack mounting points
Rip out toilet and replace with a portable - not going to happen
Trailer is done tonight except for some paint tomorrow...
I broke the cold/warm mix knob on the HVAC tonight pulling the jeep in the garage...not sure if I'll be able to get one before wednesday.
Check the air pressures in the RV and trailer tires which are new today but we didn't get to air them up to max.
Load this stuff up and leave on Wednesday!
mac 'hope it all works' gyvr
Jeep:
Change oil(or just keep adding ~3 quarts like I have been doing ) - done
Transfer case linkage adjustment - has gotten better on its own
Swap to discs/new bearings on the dana 44 - still gathering parts
Install TnT belly pan skidplate - after wf
Suburban (ready to go for WF, this stuff needs done before Harlan):
Trans flush/oil change - after wf
Ball joints/tie rod ends - done
New tires n rimz yo- done(just tires)
Figure out where the damn ac is leaking from - after wf
Trailer:
Two new tires (or keep rotating in crummy spares like I've been doing)
Repack or replace LF bearings
Replace brake magnets
I haven't gotten anything done yet today. Sitting in the er with the wife. She can barely move with back pain, so I keep calling her Dan. My day and time is dwindling away and obviously its difficult for her to deal with the kids. Could be a week full of very late nights for me!
Re: Re: Whatcha need to get done before Winterfest?
Lol.
I've never dealt with such back pain, it really sucks. I am currently planning on bringing my jeep, but it may not see the trails.
She is telling me its worse than labor pains. I feel bad for her but j can't do anything besides play Mr. Mom.
K "when life gives ya lemons, make lemonade" man
Dang it sounds like back pains are common in the Midwest. Mine has been sore for a couple days now.
You gonna be wheeling yours Dan?
wienerbox fired up today after new batteries installed.
airbag leveling valve is frozen.
so, unstick airbag system and I'm good to go.
Got my front axle in. Need to get a new ds joint tomorrow then out brakes on etc. Then go make a mount for my LED bar, and a cab mount and I'm good to go
Load her up........
Ram" The past three and half weeks have been long and sleepless"Rod
