Ecomike
NAXJA# 2091
- MilkyWay Galaxy
I finally got smart and used a garden hose to find the last window gasket leak on my 87 Wagoneer :laugh3:
Guessing sucks.
Saturn ball joints and struts are all done, all new on the 270,000 mile beast, turn signals on both vehicles done and working, pulled the Saturn power sterring pump, waiting on the replacement.....on its way, . I need someone to score me a good JY Saturn SL1 rim (2001, but they should all be the same). Started to tear into the Taurus Ford to get at the vertical transmission cover to access the valve body. Going to open her up and change the fluid pressure control solenoid for starters. Wish me luck, its a FORD.
Just needs tires and alignment on the 89, 2wd.
Cruiser54 made me a custom Renix gas tank flange removal tool. It is on its way from California (loaner-trial)
to solve the pump replacement access problem on the 89 4WD rig I have yet to get on the road. If it works, he might consider making a batch of them?
85 Diesel needs a shop near me to swap the manual Trans pressure plate, clutch and bearing.. Need to shop for one
Guessing sucks.
