- Houston, Tx
Was the jeep hot or cold?
The Only Problem I See With It Being The Map Is That The Vac Line From It To The Tb Is Pristine still
Went and got another socket from NAPA that didn't end up fitting.
Buuutttt the socket in the jeep started working fine again. Problem solved.
Put on a new radiator cap for S n' Gs. Jeep goes a little over 210 now, but the temp doesn't slowly creep higher and higher now. Amazing. Still going to convert to efans within the next month or two.
Why efans? I like the stock mechanical fan
Add a ZJ 4.0 HD fan clutch and you'll never get hot.
how Do I Test The Map Then
I figured the 3 efan setup from DirtBound offroad would be a nice setup for when I'm done mall crawling and actually go places.
Make sure you have a large enough alternator to handle the extra power loads first!!!
