i also removed my egr system
yeah mines the open system now and stays at 170 to 180ish. also how can it run cooler when your dumping hotter air into the intake. doesnt most vehicles perform better with colder air? also its purpose is to burn unburnt fuel in the exhaust. im hopeing to have less of that with the ford injectors. also the later models dont have the egr anyways they have a lil diff cam profile to help with it. ( read that on wikipedia or somethin like it)
Need to find me a 32 tooth long shaft speedo gear.
Dang thats cheap. Thanks
EGR is typically not employed at high loads because it would reduce peak power output. This is because it reduces the intake charge density. EGR is also omitted at idle (low-speed, zero load) because it would cause unstable combustion, resulting in rough idle. The EGR valve also cools the exhaust valves and makes them last far longer (a very important benefit under light cruise conditions)
(I bolded the two that would support this theory...of course he says that's just an example meaning it may not be true for all vehicles.)The above is used for illustrative purposes only. Refer to your manual or CD-ROM information system for specifics to the car you are working on.
- Engine temperature more than 170 F.
- Ambient air temperature more than 20 F.
- Engine run time more than three minutes since 170 F.
- Engine speed 2248-2688 (auto. trans.), 1952-2400 (manual trans.).
- Manifold absolute pressure from 5-20 hg.
- Short Term Adaptive Fuel Trim is adjusting pulse width by less than +7 percent and more than -8 percent.
- TP sensor from 0.6 to 1.8 volts.
- Vehicle speed sensor more than 40 mph.
