What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Re: What was done to YOUR rig today?
I am lucky... With mine being an 86, I have very few torx bits.
Tried to fix the welded up water pump mounting hole.:gonnablow:gonnablow:gonnablow:mad::mad::mad: Didn't work:cry::cry: so you can see my wanted add in the for sale section about needing an engine block.....And no you cannot drill though it. I tried that and tried welding a stud to the cast block(yes I preheated it)
Might as well build a stroker while you're at it.
cut and folded my lower quarters and cut the bumper to look better with it.
well i pb blasted my shackle bolts to make sure they would be ready to go for installing my shackle relocation brackets-they are good to go now i just need to find someone to help me weld them up before i install them...
also re-installed the front bumpstops and looked at where im going to try and trim the flares!
yesterday we put in my new leaf springs to get rid of the block that i had... now my rear end set up is 4.5" rough country springs and 1.5" teraflex shackle... whole reason for doing this was to cure my axle wrap issues. not sure that its going to work... after we finished working on our junk me and my buddies took off to go eat at chilis and one of my friends was following me in his car and said when i took off he could see my axle wrap up a little bit... and i drive like a grandma so this is bad!
I replaced my rustys uca's with wj uca's in an attempt to fix my low caster issues. It does feel a lot better now but not perfect. Don't have an angle finder so I can't measure it. The funny thing is that I added caster which in most cases will make your pinion angle worse. I seem to have lessened 60+ mph vibes now.
For those interested: it's 6" of lift with trailmaster drop brackets and rustys fixed lowers.
still in the shop til tuesday, but have a shitty chevy cobalt as a rental
Which shackle locators did you buy, that require welding???
justin-got the hdoffroad ones like you have they require welding correct???
also just got done trimming the front fenders so i dont crunch another one (hopefully) didnt have enough time for the rear so those will have to wait a couple weeks
got a new one today !!!
White 94 base model with 110k 2wd soon to be 4wd $400! new ac new battery straight body needs two font fenders NO RUST! and security system! go pick it up today! PICS soon
pics or it didn't happen!!!
congrats bro!
I dropped off my DS to get it lengthened. Now I have to get another one and have it shortened.
