Roxtar
- NW Indiana-Chicago area
Lock RiteRamsey said:what kind of locker or slip can go in an 8.25 without having to have the gears reset
2offroad said:i know some things on Andy at CarloinaRockShop so regear is not much $.
xj92 said:What is the Toyota 8" bolt pattern?
Safari Ary said:6x5.5
Kid, and ARB is not a locker, it is a selectable full spool, and that is why your handling is miserable when locked. Have you ever had an auto locker?? With an auto locker, as long as torque is not being applied to the pinion, the front wheels should freewheel through turns (i.e. when costing through a turn rather than powering through it.)kid4lyf said:I'm running a rear Detroit and front ARB and I love it. I would absolutely NOT ever go with a front full time locker. When I'm locked in front the handling is miserable, and that's with 32s. I'll spend a day at the Badlands and use the front a couple seconds at a time, when needed, and then shut it off. 95% of my trail time is spent with the front unlocked. If you don't like ARB go with one of the other selectable lockers out there.
2offroad said:the toy axle is out because of the bolt pattern. still wondering if the rear disc are worth $500. the C8.25 will hold up for me and 33"
thinking f & r regear to 4.10, Detroits f&r Terra 2 low and AA SYE about $1700 in parts labor i can do. still the rear disc pops to mind.
either the 8.8 with disc or transfercase mods?
Do 4.56's... you'll regret 4.11's. I had 4.11's with 31's and I wished for 4.56's.2offroad said:thinking f & r regear to 4.10,
Yup..... I love them on the street so farRawbrown said:Try 6.14 from Yukon for the lowest 8.8 gearset possible.
and with the $1500
you could do detroits, gears and minimum install kits with enough left over to probably pay most of the install fee, depending on who does the install.
and I think Ketjar would agree to the detroits. you could save a few $$$ by going with ezlockers front and rear. then you might have enough to do an SYE and CV shaft.
