What I need to get done before Winterfest
It does not have a balist resistor does it, I knock the wire lose on my 89 all the time, not sure if yours has one or not
Went to pull the heep in the garage today, she turns over and over and over. i think I have to change the CPS. good thing I don't care about the fire wall, I am thinking 15 minutes to change it.
Oh yea, yellow top is dead.
coils like to die as well...
mac 'maybe more common' gyvr
Pretty sure I bought the cps at autozone, lifetime warranty. Will try that first. Its too cold to be working outside (guess my jeep feels the same).
be good to see ya again Nick, my honey do list gains 5 for every one I knock out
Hey Richard,Likewise..It's been a few Harlan trips since we have wheeled.I know what you mean..As I'm finishing one,my honey is talking about the next two.
Started on the high steer yesterday.While replacing the pass steer knuckle I discovered the wheel bearings close to burning up.
There goes my short list.:repair:
Nick
My list got a lot shorter. Just need to stop the noise in my front end. Hoping its a Ujoint or something.
Just got the green light for gears and lockers...my list just got longer....
I did just get this mounted and now need to wire up the harness front and rear for the winch.
cps didn't do it, cut a hole in fire wall and changed it in 10 minutes.
Will try coil next, but I have a feeling its in the ignition.
Well I got 2 tires just need to get them mounted
Got my cb and antenna installed
Got my fire extinguisher mounted
Now trying to find some $ laying around for some stiffeners and maybe Sliders. And gas tank skid....t.c. skid....front end skid....o boy I better find slot of $
rocker protection (sliders) should be very high on the list of things to do, IMO.
Just signed up so Ill add my list.
Need:
Lots of help
Front bumper
Gas tank skid
CB
Fire Extinguisher
Front brake lines
3/4" spacer up front
Want:
Trim fenders/remove all stock plastics/"massage" inner fenders
Cut out rockers and replace with box steel
Repair drivers floorboard
Rear bumper + cut and fold
Replace 31" at's with 33" mt's
New shocks with rear crossover/flush lower mounts
Bumpstops sorted out front and rear
Beefy steering
456s lockers and alloy shafts
Longarms
I think I can actually get most of these done in time, the body work is what Ill really need help with, anyone?
I feel like I'm finally making some progress...
front ds - done
carb swap - done
dizzy swap - ended up not needing
sliders - skip again this year
new list:
track bar
shackles
t-case skid
wheel cylinders
so my "just add fuel" list has taken a drastic change.....
just scored a set of new built axles for the rig and they should be to my shop in @ 2 weeks...so now comes the fun of fabbing everything up to get them to work under a XJ. I also have full hydro steering to swap over as well.....
It just would not be WF if I was not waiting to the last minute to start a major project. :D Let the beer and chz consumption begin!!
Cheese "what the hell am I thinking?" Man
NEED:
Fix grinding vibration noise Cant find because of loud arse muffler
Put on muffler Did this one but i want to find something that doesn't suck as much
hood pins
save up cash!!! ha yea like this is gonna happen
WANT TO DO:
Cut/fold rear 1/4's
More trim for fenders
New leaf packs (prolly not gonna get done)
more than likely the list will grow more than shrink.
:D
I approve of this post!
I need to change the TRE at the drag link to get rid of a clunk & load on the trailer.
JIM.
