What I need to get done before Winterfest
I need to vaccum out the mouse turds from inside my rig.....maybe. And a new pina colada air freshner, or a Mr. T one if I can find it.
Popcan:
Replace 30 spline outters with 35 spline and drive flanges.
Baby Jeep:
Fix dad's ZJ so I can get it back and see what needs addressed.
Install Hobag shackle upgrade
Trailer:
Pending
mac 'longer than it looks' gyvr
8.8 swap, regear the front, replace front locker pins, T-case swap, and drive it there! :D
install new front bumper, wire up winch, replace fuse in CB and re-tune.
And please oh please find the $ to re-gear :)
Finish custom made cnc cut and bent front bumper with jcr tie ins
install RE adj trac bar
install adj upper control arms
instal 4.10s in d30
shave ford 8.8 axle and weld on new mounts
install new frictions in 8.8 trac lok
Install new rotors and calipers on 8.8
install rear extended brack line
trim fenders a bit
A few other odds and ends as time allows...
Jeep is gona be crazy different since last time all you yahoos saw it...
99SJ 'All on a college/student teachers budget' Ex
new transfer case
install new jcr bumper
rear axle seals
rear brakes
lockers
gears
maybe some more metal on the floors:D
IF all that was to happen the in would try for 3 more 35s for the durango and some 4:56 gears and a trailer
Hope to get after these things over the winter:
tear down and service the axles, relocate rear breather
replace TREs
replace banged up t-case Xmember
repair rear bumper
plexi windows for the rear (or keep fresh air?)
lower ride height
clean up some rock rash rust
Basically just give her some lovin.
Mid stiffeners
Sliders
Sye and ds
Make damn sure this pig can drive 9 hours one way then make it home.
Last but not least, sell a kidney or hope my tax check comes before that weekend
NEED:
Fix grinding vibration noise
Put on muffler
hood pins
save up cash!!!
WANT TO DO:
Cut/fold rear 1/4's
More trim for fenders
New leaf packs (prolly not gonna get done)
more than likely the list will grow more than shrink.
:D
get my liver checked.
Move coil mounts back 2" on axle to match the stretch.
Move rear axle back 1".
Open rear wheelwells.
Build new Chevy harness.
Put XJ harness on a diet.
Mount battery in cargo area.
T&T front inner fender panels.
Finally install mid-stiffies I bought from Brian at last year's Winterfest.
Front stiffies.
Rear discs.
Dodge 2500 MC.
New track bar mount on axle side.
Sway bar.
Redo bumpstops.
Yearly oil change.
Pray that I have enough time.
Popcan:
Baby Jeep:
Trailer:
Pending
Build living quarters in this...
mac 'or at least a warm spot to sleep :) 'gyvr
