Scorpion8
- Juneau, AK
Lessee, long and glorious list:
- Finished the passenger front window regulator install, and closed eveything back up. Works, check!
- Found my missing ambient air temp sensor lines which had been cut in the front end collision by PO. Installed a new harness at that point, and a new air temp sensor. Works, check!
- Pulled the back inside cover off the liftgate and was able to get into the mechanism and get the liftgate unlatched. Adjusted the liftgate mechanism, and tested with keys, power locks, et al. Works, check!
- Installed the battery temp sensor the right way. PO had left it rolling around under the battery tray.
- Been dorking with this in the yard so much, charged the battery while I was working.
- Wonky oil pressure sensor.
- Road-worthy lights and turn signals.
- Power window cut-off switch (see other thread).
- Get some damn use out of the thing!
