Broke spikeypuck's caulking gun trying to reattach my gutters (don't know if it worked yet)
Started on installing my ARB compressor but stopped after discovering the mounting bolts I have aren't long enough.
Also discovered a broken u-joint.
Wondered if my bike tires are still filled with air.
Mounted and wired jcr's
Bought all this for 10 bucks at garage sale. Cj7 grill is brand new!
Replaced a blown shock(Rough country ROCKS sent me a brand new one free) and started it for 20 mins, poor neglected jeep=[
7" in the front 3" in the back?
Lol, not quite that bad. The drivers side is sitting even at 5 1/2" the passenger side front is 4 3/4 and the rear is 5 7/8.
I used 1 3/4 spacers in the front, and I found the brake is in the coil spring.
I used shackles in the rear and couldn't find the brake yet. I am hoping it sags a little and evens out. Since I didn't mess with the leafs I doubt that will happen.
Made some sway bar disconnects.
The little heim joints I had from my aircraft maintenance days.
Still need to buy some bigger pins for the bottom mount and
figure out how to get the bushing end to slide off without undoint the top end.
went to tahuya for some new wheeling adventure. good fun was had by all, till something died on the jeep(thinkin cps). the trip home i got the best mpg ever. 95 miles 0 gallons
im going to go cry now ......
Still headed to the sand flea rally?
Dave
If all goes well (and fast) I am ! Dropped it off this afternoon with a guy to install gears. He says he should be able to do it in time. Its side work for him, but he knows my deadline.... D30 ring n pinion shouldnt be to hard to track down. Just hoping the carrier is still good.
:wow:
:wow:
who did you go to? if you went with the guy nick was talking about, you should have no worry's.. he's pretty cool:wave:
Capped off the back bumper and turned it into a 4 gallon air tank. Modded the ac pump to OBA including an auto oiler, oil water seperator, and 150 PSI pressure switch
Sorry to hear that Rod. I do feel a little better though knowing its not the one I gave you. Hope they get it back together in time. Its amazing this has happend to you twice in a couple of months. Are the gears a matched set.
Just asking.
:smsoap:
pulled the front diff cover... found bad news :gonnablow
Another broken cross pin !!! Pinion has 3-4 huge chunks taken out of it.
$$$$ :repair: $$$$
