What did I do to my XJ today? (Post your XJ TECH happenings)
Re: What did I do to my XJ today? (Post your XJ happenings)
replaced the water pump on my 92. last replaced it on october 3rd,2008. i hope this one last longer.
the most sucking part was,my shop is full,i can`t get anything else in it. i had to do this on the carport in the wind and blowing sleet/snow with manual tools,our power is out, and to boot,i`m recovering from my first bout ever with pneumonia.
we`ve got a 5500 watt genny for the house but it won`t run the shop compressor even if i could get my jeep in it. boo hoo,wa,wa. life is still good.
Got the Jeep back on all fours for the first time since October! Still have a bunch of little stuff to do before wheelin season.
Power washed the underside since we have had lots of ice and snow here(lots for OK) lately. I then changed the oil and greased everything.
Picked up a 241OR today for 350. Needs a new chain am also looking at a 2L and a SYE kit.
installed the new hood on my MJ :yelclap: it looks much better now
I made a track bar brace for my homebrew track bar and bracket. Now i have a straight trackbar and a beefy brace to strengthen the whole front end.
Ordered all the bulbs to convert my interior lights over to LED.
Installed a Full Size spare in the stock spare location, just need to make up a cover for it now.
replaced ignition coil and lift struts. starts a little better and i can use my liftgate without a 2x4 now.
I would rip those off in a matter of seconds! :D
that mounting spot was for testing i left enough wire to move them onto the skidplate, i have to get a hold of a welder so i can weld up some brackets they wil be above the "rock line" when re mounted! those things work great just sucks to realize there brighter than my h4's time to rewire the headlamps!
Haha, just got my Autopals today. I realized i bought the crystal clear lens e-code housings instead of the regular e-code. Oh well, if they suck too bad I'll sell them and get the regular e-codes. I also have a HD harness ready to go on for the lights. I still need to get my Tail light housings installed and swap the interior bulbs and instrument cluster bulbs to LED and I also need to get my Rails, hitch, and all my skids on before WF and trim my rear bumper caps! Damn, I'm gonna be busy!
went down and bought a new set of wheels and got em installed =)
I Cut off my old factory shock mounts on my jeep and welded up some new ones for my bilstein 7100s. I Also got my 4.56 gears that i gotta put in this week too. And then it is roll cage time
Today I started working on the mounting for my Taurus Electric Fan conversion. Replaced water pump, thermostat, lower radiator hose and flushed the radiator out.
If you need any help wiring that up, shoot me a PM. I used a taurus fan for a while.
I'm a stonemason so there's always a 5 gal bucket in my trunk full of hammers, chisels, bars, etc... I was tired of it always falling over and dumping my tools out so I drilled a hole in the bucket and used the spare tire mount and screwed the bucket to that with the factory wingnut. (my spare tire is on the roof rack) no more spilled tools!! pics in the fab section on cherokeeforum.com
/\ great, cheap mod! good stuff! /\
I drilled and tapped my costco compressor for a standard 1/4 fitting on superbowl sunday. Now it'll take any standard fitting.
yay! OBA here I come.
I also installed a non ghetto looking black flexible antenna. Matches my black/silver color scheme much better. :)
