fdsa487
- El Cajon, a.k.a. The Box
Ok well i read on here that im supposed to use Dextron/Mecron III... The guy at Kragan SAYS "you only use that to top it off. If you doing a full flush you want to use Dextron +3" THEN he looked in the computer and the computer says that Crysler recommends that i use Dextron +4 WTF! Transmission are expensive and i dont want to have to buy another one just because i used the wrong tranny fluid. Honestly what do you guys think i should get? Stick w/ the Dextron/Mercon III, the Dextron +3 or the Dextron +4...
Im 99% sure the tranny is an AW4... Is AW4 the model number?
BTW the Jeep is a 2000 Cherokee XJ, 4.0 I6, 4x4 w/ a NP231 T-case.
