fenns7
- London; UK
My 1996 XJ (RHD) with AW4 and 242 has had a small leak of tranny fluid since I've owned it (6+ years) so I check the level regularly and top up frequently but it's now getting worse and a pain in the rear end so I'm trying to locate the source and make it oil tight once and for all.
I'm going to replace the filter and gasket with quality items but notice that there is a bolt on the bottom of the T/case that is dripping Dextron III. Something in the depths of memory tells me this isn't a fastener you mess with as it locates something internally - is this right? Either way I'm pretty sure this isn't the drain plug so I'm reluctant to tighten it up.
BTW I dont see any evidence of leaks higher up the g/box but will be doing a de-grease and clean up to double check this.
