Run it. No need to get bizarre unless it doesn’t work.
I've sheared the studs off a high steer arm, though it was a slight speed impact, and the studs weren't ARP's (stronger).
Was that when you were trying to keep up with a JK?![]()
I'm scheduled to close on my new house Wed. Just did the final "blue tape" walk through today. 3 car garage is 26ft deep with 12ft ceilings. Oh, and there are some bedrooms, bathrooms, and a kitchen too.
So, the tube is welded to the center section. I have an artec link tower for the upper link mount. I was planning on adding some sort of truss into it but I want to get the track bar mount on too then I will pull it out and do that. Wont be anything big but something to tie it all together.
I hadn't planned on doing anything more with the knuckles. I was asking a while back about them and didn't get a whole lot back. Yea they're just plated front and rear. Front has double shear mount for steering and a big gusset for the knuckle. I wanted to run hydro assist mounted to the tie rod so I was hoping that would keep the load off the high steer arm. Still think it needs to be tied together? Really I'd just like to get a year out of these until I can get some rieds or solid knuckles. Whatcha guys think?
Ummmm, that JK was behind me IIRC
Hell yeah, look awesome!
Having more room to work is nice. Though my F-350 still doesn't fit in my shop...
Well, this should make 1Ton happy. My old 7.3L had a mechanical issue this week. Fuel filter housing drain valve started leaking. Damn O-rings only lasting 18 years!!
And in another week my truck's arse won't have to hang out of the garage when getting some TLC
Selling mine. Building new house after fire.
Tell somebody in Texas
89 cherokee 4x4 258 $650 No title Interior good, Ext. Fair, needs paint
89 comanche rare metric tonne 4x4 258 $850 No title Bed dent rear quarter needs paint
95 cherokee 5spd 4.0 $850 Title Engine tick Great ext,int. shot
01 Cherokee 4x4 4.0 Nice $3200 Title 240k
Jacksboro TX
Still have the old yellow o rings? Never seen one of the new ones with the green one is rings leak.
Good news on the house!
Like I said, I knew it would make you happy that an 18 year old o-ring started leaking and made me fix something on my truck. Any chance you get to nut swing about your Cummins you'll take.
Although I haven't had to replace my radiator cap yet. Just saying.
Tow truck driver? From a leaky fuel bowl drain? Do you even know diesel? Maybe your fancy Fiat throws a CEL and goes into limp mode every time a seagull sneezes while flying through a northern wind. The old International 7.3 doesn’t even know how to limp mode. It’s just drips and marks it’s territory while still chugging along.
