old_man
- Loveland, Colorado
Contact RangerRick, he has more experience than he wanted with those.Just got done installing this new to me 4-1 case, and it has a click/ratchety noise in 2 or 4 hi. any words of advice?
return it lolJust got done installing this new to me 4-1 case, and it has a click/ratchety noise in 2 or 4 hi. any words of advice?
Synthetic ATF that's recommended for it. Never broken a case open before, but it looks like I might have to. Chain shouldn't be spinning in neutral right?
Kinda angry because the logic of: it worked perfect when it came out / putting it in and now its not perfect, just isn't working for me.
Crunchy
Listen through the end; It is first gear through fourth gear.
Got any oil in that piece of scrap?
You need to crack that thing open.
The Tera 4 to 1 does have an Achilles heal. It can't handle speeds over 3000 rpm in high gear (2200 rpm in OD), so you have to limit your speed sometimes in low range, or just shift into high range if you're going to run quicker through a section of trail....... The weakness is the pins that hold the small pinion gears in the planetary housing. They are staked to hold them in the case, which is using a punch to make indentations around the edges of the holes in the case to hold the pinion pins in place. Mine broke one time (and I wasn't paying attention to over revving it), and one of those pins came out of the case and broke. I heard through a friend, that was using a 4 to 1 in competition, that Tera recommended putting a tack weld on the ends of those pins to hold them in the case better, so I did that and haven't had any problems with mine in the five years since doing that.
WOW!!
Time to get a refund.....
Did they say "no charge?"Teraflex is really standing behind their product, and are saying they will go through it for me.
