UnlimitedMatt
- Cheyenne, Wyoming
More teasers of my mall rated junk...
Going to try and hit up emissions tomorrow. I need to test this thing out!
It looks sad without the turbo...
What front sway bar is that? Or at least, what arms are those on the anti-rock?
Awesome man, thanks. I just went through your build thread again. Great stuff.
Do you think those rear shock towers would be strong enough to be part of a roll cage? I'm basically thinking of having the c-pillar attach to the top of it and having a cross bar and rear brace like how you have yours.
I think they have 3 cup holders too, bad ass. Good call, Mike.
Yeah gonna cut it all to pieces and then sell it after I put a few scratches on er.
Well, just as I am making progress on getting the new engine tuned right, there are drips of red oily fluid dripping off of the bell housing. Guessing the AX-15 is leaking at it's front seal onto my new clutch that up till has worked better than any I've had before(total of 6 maybe?).
Tps shouldn't cause that. What are your fuel trims per your WB? Usually high NOx is from lean conditions. Could be a bad o2. I love el paso county- no gas program here!
So, went to emissions yesterday and failed horribly on the NoX. 4.3 out of 2 max. WTF. Air/fuels seem to be good according to the wide-band. I hooked up my scanner and noticed that my TPS is showing 13% at idle? I don't think I've noticed it being that high at idle but can't remember. I don't have a CEL either, but could the sensor be dying?
Did your jeep sit for a while as a build before the test? If so, how long?
The one time my 4.0 failed emissions (ever) was really high NOx and it was after sitting under the knife for 2 years. I had a full tank of 2+ year old fuel in it. I drained the tank, put in some premium 91 octane gas, ran about 1/2 a tank with some engine cleaner from the parts store, then filled it back up with premium and went to re-test and it passed again.
Wouldn't hurt to verify your exhaust is ok. Never know. Simple vacuum gauge can tell you a lot. Did you fail or come close to failing any other test points?
