YELLAHEEP
- Littleton, Colorado
did we adopt Kastein into our chapter or some thing?
I know right? Friggin' chatty Cathy around here.......
it made no difference . i am really out of money and massively frustrated at this point. i need to have it working so i can get plates on it. i have other things i need to repair on it but this is most important.
Digger, I'm looking at this and thinking...
341 square inches (stock XJ 4.0 radiator) = ~2.4 square feet
589 square inches (stock BR 5.9 radiator) = ~4.1 square feet
That's only a difference of around 1.7 square feet, 21"x12". I've seen small radiators from passenger cars that are around that big, maybe run one in tandem with the main radiator. Any thoughts on where to mount one?
Mine's going to be a pavement queen so I may be able to pick up that much area inside the fronts of the fender wells with a large heater core and a fan + ducting, but I don't think that'll work for you.
:eyes:did we adopt Kastein into our chapter or some thing?
You were going to replace those anyway. :gee:The tension was so great that the engine valve cover was pressed against the firewall pulling against the engine mounts.
sorry which is the sync sensor? in the distributor?No change would suggest to me that there is something amiss with the sync sensor.
If the timing has too much advance, the charge would light before the intake valve is closed.hmmmm
cap rotor etc?
if the dist is set wrong i can see how that can cause a ton of crap. more so if the advance is extreme and too far. as in firing with an open exh valve and burning the crap down the pipe and not in the cylinder. hmm i ll go check out my junk. so to speak LOL
Gunter said:sorry which is the sync sensor? in the distributor?
yes, with trouble.Here is a question for the RENIX guys: Will a RENIX even start with the distributor improperly indexed? What if the timing chain were to jump a tooth? :dunno:
So deflated....
First time up an RTI ramp today and made it about 2 feet before my left front tire mashed into the wheel well. :smsoap:
Got underneath and realized the PO jerry rigged the entire UCA's setup, and because of it, the axle sits about 4" inches too far back, not allowing the wheel to tuck evenly.
I'm so F-in mad! Guess it was better to find out now, rather than on a trail and breaking.
So my plan is to modify the current UCAs to a 3-link setup like the Rubicon Express arms. Weld mounting plates to my LCA's and running the UCA's accordingly.
Jim
!!!1!!!1!!!1!!!1Pass on building y links
If you're gonna do long arms do a true three linkbecause y links bind like a Bitch
You'll chew up uca bushings like mad
!!!1!!!1!!!1!!!1
Wrong....
Y-links provide more than enough flex.
!!!1!!!1!!!1!!!1
Wrong....
Seems you drank the Kool-aid before checking the label.
Seeing Spots,
We've all heard about a certain member that damn near pissed himself when his suspension moved 1 wheel a little higher than the the other three on Grizzly Lake.....so becareful about who's advice you take.
