What are you doing to your rig - the continuing saga
Got my bucket cleaned up. Did allot of re spraying from the wheel wells, bumper and rear quarter armor.
Degreased under the hood and vacumed the shit out of her as well. Got some cb radio wires clean up wile I ws at it.
Ah, like moths to a flame ... ;)
Just spent a full week in Moab wheelin in my golf cart. Did over 120 miles, did Hell's Revenge, Fins & Things, Flat Iron Mesa, Behind the Rocks, Steel Bender, Strike Ravine, & Green Day. Used less than a tank of gas ( which is 8 gallons ), never winched once, and never put a wrench on it the entire trip. :D Twas a good trip!! :thumbup:
front end on the WJ is finally pretty much de-clunked... after a good reaming from FrankZ :eyes:, the pitman arm no longer has a wiggle, and I found a loose sway mount to boot! :cheers:
Oh Lordy Lordy...I have gone against my own rule of not backyard engineering things.
After taking the rig out for its first 100+ mile ride over the weekend, the steering was still really jittery at highway speeds; so I added my old steering stabilizer to help things out.
The Ruff Stuff 1 ton steering system leaves barely any room to mount the SS, so I butt-welded a 1/2" Grade 8 to the 7/8" Grade 8 bolt for the Track Bar. I did 2 passes with .35 wire so I know I got good penetration. I'm not sure how long this thing will last without a double sheer, but it'll do for now until I get my new Dana 60. :)
Overall adding this made a HUGE difference and I'm loving my rig again.
Jim
Jim
:huh:
How much of that 1/2-inch bolt changed color? Where did the colors stop?
:huh:
It was an old bolt so the different color is just wear and rust that I brushed off.
Oh Jim.....you better start tanning with rigging like that
Oh whatever...it's a secondary stress point. It'll hold until the end of the summer.
We used to tack 1/2-inch bolts at work, until they started breaking where the discoloration stopped. It does not seem to be a problem with bigger bolts, probably because they have more material to dissipate any heat we put to them.
BTW, we use only high tensile bolts, SAE Grade 5, ATSM A-325, or higher grade.
If the bolt made it to torque, it'll probably be OK...
dudes i am plotting my first lift of any sort.
spring over rear.
gonna be a piece it together from junk sort of a deal. what lift of springs should i be looking for for the front?4 or 6 inch? the rear of the MJ has some shackles that added ...hmm ... 1 and a 1/2 maybe 2 inches. so that plus whatever spring over will give me.
thanks--
carry on
I likewise had some grade 8 s snap right at the bluing line when welded to my d44 under the xj as shock mounts... Repeatedly.
spring over rear.
thanks--
carry on
Might just be me but 6" is too tall... I am right at 3-4" or so with 33s and wouldn't go any higher. In fact I'm going to try and keep it right where it is when I go to 37s.
I went with some unknown set of 4" coils I bought from a friend for 30 bucks and a set of Rustys 4.5" SUA MJ leafs. Didn't want enough lift to go spring over axle and my leafs were totally shot anyways.
